ImageTexture animation only renders first image.
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
MadsBroni
Hello there,
I'm trying to cast an animated shadow from a light distributor with ImageTexture. Works great with a single image, but importing a .jpeg sequence (file 001) it only shows for the first frame.
I've manually tried to setup the start frame and end frame, but without luck. Where am I going wrong?
..also pardon me if I'm posting in the wrong forum, but for some reason I can't post in Plugin Discussion/Support › Maxon Cinema 4D
Mads
Manual part: https://docs.otoy.com/#60Image%20Textures
Which version? It should work fine if there's not very extra-ordinary characters in file name. What's your file path?
Return to “Bug Reports”
