OctaneRender™ Standalone 3.03.2
abstrax
Hi all,
This is a small update of 3.03 Standalone providing more more bug fixes and experimental Pascal support.
License tracking change since 3.02
To implement the floating licensing system we need to keep track of all Octane processes that use a specific license on the computer. This way we only release/deactivate a license when no Octane process is using that license anymore. Originally we used a third-party library for that. Unfortunately there were various issues with that and caused crashes during startup in various circumstances. To fix the problem we changed it to an internal (file based) system in version 3.02. Unfortunately this separates the license usage tracking of version 3.02 and higher from the usage tracking of 3.00, 3.01 and 3.01.1.
-> Please make sure that you only run either version 3.00, 3.01 and 3.01.1 at the same time or only version 3.02 or higher.
Experimental Pascal GPU support
We could narrow down the issue using the CUDA 8 RC toolkit and were able to work around it by doing a mixed CUDA 7.5/8 build for Pascal GPUs. For previous architectures we still use CUDA 7.5 only. This is all experimental and we haven't done any specific Pascal tweaks/optimizations yet and the performance isn't where we would expect it to be, but at least you can use your Pascal GPUs now.
Changes since version 3.03.1
  • Fixed "invert absorption" option of the scattering and volume medium nodes (see viewtopic.php?p=282396#p282396).
  • Fixed baking camera if a negative scale is used for a baked instance.
  • Fixed version number display in daemon list of the net render configuration dialog (see viewtopic.php?p=282451#p282451).
  • Disabled visual deactivation of work pane components when a modal dialog is open (see viewtopic.php?p=282535#p282535).
  • Net render settings are now saved as soon as the net render settings dialog is closed (see viewtopic.php?p=282615#p282615).
  • When Octane detects that the currently used license has been deactivated, it tries to get a new license and if that fails allows you to save the project before closing the application.
  • Fixed calculation of expected total render time when the non-interactive render region is being used.
  • Module SDK: Text labels are now modifiable.
  • Module SDK: Extended the selection manager wrapper.
OctaneRender Standalone downloads
16/7/2016: We updated all OSX builds and the commercial Windows builds to fix a random deadlock during startup.
18/7/2016: The commercial Linux build has been updated too now.
Windows
- 64-bit commercial version (ZIP archive) - update on 16/7/2016
- 64-bit demo version (ZIP archive)
Mac OS X
- 64-bit commercial version (DMG image) - update on 16/7/2016
- 64-bit demo version (DMG image) - update on 16/7/2016
Linux
- 64-bit commercial version (ZIP archive) - updated on 18/7/2016
Photoshop workflow plugin download
You can download and install the plugin either via the Adobe Exchange platform or you can download it from the link below and manually install it.
Windows and Mac OS X
- Photoshop extension (v1.0.3) (ZXP archive)
Happy rendering,
Your OTOY NZ Team
ff7darkcloud
Thank you. Can't wait to test this with a Pascal card!, will be ordering one soon.
( PC ) Win10 x64 | 2xRTX2080TI | ASUS Rampage VI Extreme | i9-7900x | 32GB | 1600W
( Laptop ) Win10 x64 | RTX2080Max-Q | Lenovo Legion Y740 | i7-9750H | 32GB - Octane Standalone Win 10/ Sketchup 2019
PORTFOLIO: https://renderspace.wixsite.com/portfolio
Lewis
Thanks for update Abstrax.
Can you elaborate more what this licensing mean sin practical work ?
Especally this part:
"-> Please make sure that you only run either version 3.00, 3.01 and 3.01.1 at the same time or only version 3.02 or higher."
My usual workflow in octane arch-Viz is while working on main scene in Octane 3.0 i start First LightWave layout and put all furniture, details in there and start building overall scene.
But i open 2nd LightWave (all on same machine/license) and texture furniture there in my "studio" or "daylight" scene so it's much quicker to work and neutral to make textures before putting them in to the room/different lighting scenario. BUT i do that in Octane 2.25 (different LightWave installation so i can octane 3.x and v2.25 on same machine but different LightWave installations and since 2.25 is much more repsonsive/faster on tumbling speed due no Tonemap option back then.
With this new info/licensing it seems that type of workflow is not possible anymore or i got it all wrong ?
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
mojave
Lewis wrote:Thanks for update Abstrax.
You should be able to continue working using 2.x and 3.x on the same box with no problems (just check this if you are using OSX).
This limitation applies just to using different 3.x versions of standalone/plugins on the same machine and at the same time.
Lewis
mojave wrote: You should be able to continue working using 2.x and 3.x on the same box with no problems (just check this if you are using OSX).
Thanks for quick answer, that puts me on ease then.
BTW yes I'm on windows (check the signature with specs ;)).
Lewis
Skype - lewis3d
ICQ - 7128177
noldo
If i run 3.02 the program start, but if i run 3.03 the program freeze at the startup screen... Why?
Solved!
abstrax
noldo wrote:If i run 3.02 the program start, but if i run 3.03 the program freeze at the startup screen... Why?
Solved!
Yes. This is a random deadlock we missed before we released this version. Should be fixed now for Windows and OSX. The Linux build will be added as soon as it's available. Apologies for the inconvenience.
seltzdesign
ff7darkcloud wrote:Thank you. Can't wait to test this with a Pascal card!, will be ordering one soon.
Just ordered a GTX 1070 (Asus Strix). Will be picking it up on monday and hopefully test it right away, although I am not holding my breath performance-wise. But still intruiged. I guess OctaneBench doesn't have Pascal support yet anyways and wont till they have fixed everything. It will come eventually.. got the HTC Vive coming today as well though, so I will keep myself busy with that till Octane runs smoothly on Pascal :roll: :lol:
If you are not failing every now and again, it's a sign you are not doing anything very innovative.
- Woody Allen
Dual Xeon | 32GB Ram | 4 x GTX 580
smicha
Please drop a note how it performs compared toyour 580
ramiz
Just tried this on my 1080.... AMAZING!!!! Can't wait for the C4D Plugin to come out!!! :D
Does anyone have links as to how I can benchmark it?
