IMPORT MATERIAL AS SEQUENCES
Goldrakes73
Hi! how set the sequences in the material editor? I can't see play this sequences... which setting I'm wrong?
There is a manual for this new feature?
Marcello
Goldrakes73
no everyone can answer me? please?(((((((
azen
Goldrakes73 wrote:no everyone can answer me? please?(((((((
Apologies for the belated response.
Please show the setup for this material (in Slate Material editor). What type of material is this map added to? Is it added to a Diffuse material?
Goldrakes73
Maybe It's better change my question: how is the correct procedure for setting a material like a sequence of frames in the environment? or just as material to apply for example to a plane?
azen
The RGB Map seems set up OK. Assign it to a diffuse material, and apply that to your scene. If this doesn't work, let me know and I will take a further look into your setup.
Return to “Autodesk 3Ds Max”
