OctaneRender® for 3ds max® v3.02 - 4.4 [OBSOLETE]
Locked
This is the test release with new features implemented, so some issues are expected. Please report the bugs in the "Bug reports" section.
Changes of the 4.4 version
  • PhoenixFD simulator object without OctaneVolume modifier applied is now considered a mesh by Octane. This is usable if you tend to enable "Show mesh" in it and render it as a mesh, not as a volume.
  • Fixed IES distribution visualisation bug appeared for some specific locales.
  • Minor fixes and improvements...
Previous versions changelog (since major 4.0 plugin release):
Changes of the 4.3 version
- Implemented new kind of Environment - "Visible environment". The existing Octane DayLight object ideology is changed. Now you can use up to two of those objects in a scene - one for main environment and one for visible environment (the new "Kind" attribute). And now you can set either of those to either "Daylight" or "Texture" environment type (the new "Type" attribute). In this case, if the main environment node is set to "Texture" type - it will replace the Octane environment map set in 3ds Max standard settings (if any).
- Added error logging to IES visualisation functionality. If you have issues with displaying IES distribution in 3ds Max viewport - attach please the Octane error log to the bugreport.
- Minor fixes and improvements...
Changes of the 4.2 version
- Fixed image textures bug.
Changes of the 4.1 version
- Implemented the PhoenixFD simulator support. You need to apply the new "OctaneVolume" modifier on top of simulator object to have access to additional Octane-specific settings. Mapping of PhoenixFD channels to Octane: temperature -> emission, smoke -> apsorption -> scatter, and velocity -> velocity.
- Implemented a feeding of Octane image textures by non-Octane textures input. Now not only BitmapTex can be connected to "bitmap" attribute of Octane image textures. In this case the new "Bake input scale" and "Bake input resolution" attributes of Octane image texture must be tuned accordingly. But I still advise you to not abuse this approach too much, and still use the old efficient way: manually baking the texture to the file and use this file in created Octane image node. Because in the latter case you will do this manual baking only once - when you are creating the texture. But when you use this "on the fly" texture baking approach - the plugin will render (using standard 3ds Max CPU-calculated nodes) and bake every such texture every time during scene translation. So, if you have quite a few of such textures with high baking-resolution set - it will significantly increase the scene translation time. My measures for just one 3ds Max "Marble texture" show about 67ms rendering and baking it into 512x512 image buffer, and about 1500ms to do the same into 4092x4092 image buffer. Multiply this by amount of your non-Octane textures in the Octane scene - and you will get the overall slowdown time of every translation stage (the CPU-stage before Octane even starts to render on GPU).
Changes of the 4.0 version
- Implemented the support of "Time" settings of standard BitmapTex when it is connected to any of Octane image textures. "Sync Frames to Particle Age" currently is not supported - this needs the support on Octane rendering core level.
- Implemented advanced file sequence settings for Octane image textures and volume object. The "digits number" setting only makes sense when direct file sequence is used (not an IFL file). The "end condition" makes sense only when IFL file is used. The "start frame" and "playback rate" are used in both modes.
- Textures preview now respects the timeline position when generated.
- Implemented the distribution visualisation for Octane IES lights having target. See the new "IES distribution visualisation" section in Octane settings.
You can read about new features of OctaneRender™ 3.0 here:
viewtopic.php?f=33&t=51679
DOWNLOAD
THIS MAJOR VERSION'S SCENE FORMAT IS NOT COMPATIBLE WITH PRE-2.0 PLUGIN VERSIONS! DON'T SWITCH THE CURRENT CRITICAL PROJECTS TO THIS AND LATER RELEASES!!!
Read the changelog of 2.X branch and discussions in previous threads of 2.X versions.
You can use the materials export/import to/from LocalDB to transfer the materials between 1.X branch versions and current versions.
Or the 2-stage converter.
OctaneRender for 3ds Max 3.02 - 4.4
DEMO version:
OctaneRender for 3ds Max 3.02 - 4.4 DEMO
If you need to see the changelog of current rendering core, or download standalone installer to get network slave and daemon please find it here:
viewtopic.php?f=24&t=54805
Next version HERE.
Locked
