OctaneRender™ for Blender 2.25 - 9.12 Linux [OBSOLETE]
Locked
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed repeating crash bug.
Installation:
- If you need to run the OctaneServer - run it as daemon:
$ OctaneServer &
DOWNLOAD
Blender Octane Edition - v9.12 Linux
DEMO is available..
Blender Octane Edition DEMO - v9.12 Linux
viewtopic.php?f=24&t=52329
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
Synthercat
Tried this on a fresh Mint 18 (BETA) setup because windows (9.12 Blender Octane) kept crashing my Octane server on project
Now....
I get a "error while loading shared libraries: libvpx.so.1: cannot open shared object file: No such file or directory"
Do I search and make link to that?
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
afecelis
Synthercat wrote:Tried this on a fresh Mint 18 (BETA) setup because windows (9.12 Blender Octane) kept crashing my Octane server on project
Now....
Hi Synthercat,
That's one of the issues when running the latest and greatest version of mint (and other linux-based OSs). No problem here with Linux Mint 17.2. Try doing a symlink to the library and see if it starts. ;)
regards,
Alvaro
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
grimm
I'm running 17.3 with no issues so far.
Synthercat
For all you with a fresh install of Mint 18 :
1.
cd /usr/lib/x86_64-linux-gnu
sudo ln -s libvpx.so.3 libvpx.so.1
sudo ln -s libopenjpeg.so.1.5.2 libopenjpeg.so.2
2.
Then just create a launcher that points to a text file that contains this :
OctaneServer &
/usr/local/OctaneBlender/blender
3.
Right click that text file and go to properties
Go to Permissions and click Allow executing file as program
afecelis
Synthercat wrote:For all you with a fresh install of Mint 18 :
1.
2.
OctaneServer &
3.
Great! thanks a lot! :D
Synthercat
I get the "Color management: using fallback mode for management" message on terminal and color management does not work (I am locked to sRGB and can't change it)
Normal blender downloaded to a folder and run from there has a working color management and does not produce that warning on terminal
Next version HERE.
Locked
