OctaneRender™ for Blender 2.25 - 9.12 Win [OBSOLETE]
Locked
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Fixed repeating crash bug.
Blender Octane Edition - 9.12 (2.76)
Octane Server - 2.25 - 9.12
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.25 - 9.12
viewtopic.php?f=24&t=52329
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
dreif
Ok,here goes using 2.25-9.12
Octane server crashes on first start up on preview render.
Restart server and get the "No Render server at address 127.0.0.1"
3rd restart of server and get Waiting for image...., server crashes.
4th restart of server, preview render starts, renders to 12 samples then stops, server crashes.
5th restart of server, back to Waiting for image...., server crashes.
6th restart of server, renders to 4 samples then stops, server crashes.
7th restart of server, renders to 14 samples then stops, server crashes.
8th restart of server, then restart Blender, server crashes.
Restarted server, just for shits and giggles, tried an F12 render, server crashes.
All the while through this there is nothing in the LDB window although the server address 127.0.0.1 is there in the LDB window header.
Now last night I had to restart the server 3 times to get things going, but it's always a different scenario like this every time I try to use
2.25-9.12 and even when it works there is nothing in the LDB window.
Using NVIDIA driver 368.39.
I am perplexed.
Win 7x64/GTX TITAN/Amd Phenom IIx4 955/16gb (The render tra la la)
dreif
How long ago have you downloaded and installed the OctaneServer? Please try this: viewtopic.php?p=281732#p281732
dreif
That seems to have done it!
Big :D to you JimStar. Thank you.
fivebythree
JimStar wrote:dreif
Went there, can't reply...
Server isn't working for me. Reinstalled over and over, as suggested. Octane Server.exe not responding, groundhog day!
I've only ever got Octane Blender running once, and that was last year when I bought the plugin. Since then all crashing server. Is this something that will be coded into the custom blender for release 3? I'll continue using Blender, just not with Octane render.
STANDALONE+STUDIO WIN11PRO | RTX3090 | XEON 4210 20 CORE | 96GBRam
enricocerica
I''m getting mad.
I'm trying to use the motion blur, it works fine with a moving object but not with an exploding mesh, it renders the mesh for the displayed frame without taking into consideration the moving faces resulting from the explosion. I tried with moving proxy and reshapable proxy without success.
Any advise ?
http://www.myline.be
aLeXXtoR
Is your animation is baked frame by frame? How did u do that explosion animation exactly?
Win 10 Pro 64bit | GeForce RTX 2070 SUPER 8Gb | AMD Ryzen 7 3700X | 32GB RAM
WebSite
Showreel
enricocerica
aLeXXtoR wrote:Is your animation is baked frame by frame? How did u do that explosion animation exactly?
I'm using the explode modifier.
Next version HERE.
Locked
