If I upgrade to V3 license, can i still use V2
aeolian001
If I upgrade standalone and lightwave plugin V2 license to V3, can i still use V2 with V3 license?
I noticed some people mentioned the new V3 version renders slower than V2, just want to know I have that option before upgrading.
Steve
juanjgon
Yes, in theory you should be able to run the v2.2 plugin without problems after upgrade to 3.0
mojave
Yes, V2 and V3 can co-exist on the same machine using a single license.
You may find all information about the new licensing system here.
Regarding to render speed, you might need to tweak your kernel setup depending on your scene if you notice an speed reduction on your scene (specially "Parallel samples" and "Max tile samples" - see here-), but should be able to get render speed improvements in most cases.
Best,
Return to “Lightwave 3D”
