Displacement mapping problem
rv3d
Uv sets in Displacement Mesh UV projection doesn`t work. Same texture settings in bump mapping work well.
azen
Hey,
Thanks for bringing this to our attention. To help us better understand your situation, do you have screenshots capturing your issue? I will attempt to duplicate your issue on a simple scene. If I am unable to duplicate, I will ask you some follow-up questions.
Azen
rv3d
Thank you for reply Azen. You can find simple scene in attachment. Cylinder is mapped with 2 UVW Maps. Mapping from top has ID 1 and from side ID 2. Mapping UV projection is set to ID 2, but it doesn`t work.
displacement_scene.zip
(196.23 KiB) Downloaded 179 times
azen
Thank you for the scene! I have downloaded it, and look forward to getting as much insight as possible into this issue.
Azen
rv3d
Thank you Azen.
azen
Apologies for the belated response.
Please confirm what version of the plugin you are using. I have tested in 3.17 and it seems to work fine.
If you could supply a screenshot, that would be great.
Return to “Autodesk 3Ds Max”
