UI Problems Please fix this.
oguzbir
I have few remarks about the new UI in materials with the latest 4.0
Especially the new RGB Image node's UI is now ridiculously messed up.
Having the Sequence and Time properties on top of all major variables and buttons is too bad IMO
Could you please correct that. Power, Gamma, UV transform and projection + Border mode far more important than the Sequence properties.
Have them placed at the bottom please.
While you do that please also align all the values to the left. So that it will be much easier for us. To input values.
I made a quick mock up of the current and my expected UI alignment.
Drop in a line. If you care :)
My Portfolio
ramone163
100% agree
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
mark0spasic
I agree Oguzbir mock up is much easier to perceive.
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
HHbomb
agree too :-)
it would be great too, to have tab key jumping to next value too, sometimes is not the case.
azen
Wow, that is an impressive revision of the UI! Re-aligning UI objects is a straight-forward job. If this doesn't make it into the next release, feel free to bump this post.
Thanks, not only for the suggestion, but for taking the time to put together a proof of concept to boot.
Azen
Return to “User Requests”
