Multipass rendering
Carrara (Integrated Plugin developed by Sighman)
tschwenke
I just installed the latest version (3.02.00.15) but the problem persists: I cannot render Multi-Layers. Do I something wrong here? All I see is 0/0 under "Samples/px." Can I change that somewhere?
Best wishes,
Thomas
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
Sighman
LayerTest.zip
(3.2 KiB) Downloaded 398 times
You need to add Octane Object Layer modifiers to your objects and then set their layer number.
You then need to select the layer you want to render in the Octane Render Target - Render Layer settings.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
tschwenke
Hi Sighman,
Nope, doesn't work either. Here is a picture of the problem: https://www.dropbox.com/s/1rv1lcw76tkc4 ... -Layer.jpg
Best wishes,
Thomas
Sighman
Looks like you are talking about render passes, not render layers, so ignore my first reply.
It looks like there are indeed issues with render pass rendering. The Octane team keeps changing the API on me and this one slipped through the cracks.
Saving a single frame using the Save Render Passes button on the Octane Render Viewport works. However, the progress indicators are not updating.
Rendering an animation with render passes (Multi-Layer) enabled is not working at all.
I work on this next.
Sighman
A fix has been posted here.
tschwenke
Great, thanks alot Sighman :)
tschwenke
Hi Sigman,
Here I am again :)
Doesn't work for me here. First, I cannot tell Octane Render to render e.g. shadows with e.g. 128 samples. It always "tries" to render with the same as the Beauty render. However, this also does not work, because if I want to render an animation, it renders only 40 samples (not 10.000). So, there is still a problem :)
Best wishes,
Thomas
Sighman
Please send me a simple scene where you have configured the render target to get what you want.
Note that, if you can't configure it, it is not supported.
Also note:
All render passes, except info passes, use the number of sample configured in the kernel. You cannot have separate max samples for different render passes.
Info passes have their own max samples. Setting max samples for info passes has no effect on the other render passes.
tschwenke
Hi Sighman,
Thanks for your answer. In fact, you can take whatever scene you like :)
Here is a simple sphere moving around. 3000 samples should be enough. You can now try to create an animation and will see that Octane will NOT render 3000 samples but roughly 40 :)
https://www.dropbox.com/s/ah5p8o5c7it795w/test.car
Best wishes,
Thomas
Sighman
My bad. :oops:
Return to “Carrara”
