Help - how to render vertex color in octane
- Norman_Stansfield
Is this possible at all? There is no map like this. I use a lot of VC in my scenes, especially with frost and particle meshing. This is the only and last thing that I have vray installed on my system. If vertex color rendering is present in octane 3.0 for 3dsmax, I can uninstall vray forever, now.
Hey,
Vertex color support is not currently available in Octane. Something along these lines could be a possibility in the future, but there are too many high priority tasks at the moment to make time for this implementation.
The most viable workaround would be to utilize a Texture Map/UV solution. See here for reference: viewtopic.php?f=9&t=29951
Azen
Azen
- mark0spasic
Can we get some update on Vertex Color?
AMD FX 6300, 24 GB RAM, Gigabyte ga-990fxa-ud5, 2x MSI GTX 780 3GB
- paride4331
Hi mark0spasic,
it would be helpful to have support for vertex color as 3dsMax other maps.
To make this would be necessary in any case an automatic baking process.
I suppose that will be implemented in the near future as it had for other maps as composite.
I will ask the developers if there is a roadmap about maps.
Regards
Paride
Regards
Paride
Is there any support for this? I need to get some vertex colors rendered.
PURE3D Visualisierungen
- paride4331
Hi mbetke,mbetke wrote:Is there any support for this? I need to get some vertex colors rendered.
https://docs.otoy.com/3DSMaxH/3DSMaxPlu ... rch-baking
Regards
Paride
