in the standalone version we can define new material under the "Local DB" Tab.
How can I access the "Local DB Material" in Carrara ?
Is there a way to use it or import it ?
The plugin has a "LiveDB" Tab but no "LocalDB" Tab.
Accces to Local DB Material.
- sebastienouellet
I found the answer.
When you edit the material in the node editor.
Delete all node except the material out.
Select Import and go to the "Local DB" directory defined in the Standalone Edition and select the material to be use.
And then, connect the output of the selected material to the "Material Out"
Close the Node Editor and click OK to apply the changes to master shader.
