I have a scene with a Octane daylight and building, I set a background image using RGB Image and then assigned it in the "Background Map:" under "Environment and Effects". I can see it perfectly in my viewport when I loaded it with "Use files" under Background Tab. But it will not render when I check "use viewport background" under Kernel. Am I missing something or is this a bug?
Scratch that...it works under Octanerender viewport, but not if you hit render.
3.14 Version "use viewport background" Doesn't work
C. RAM Capacity (i.e. 6 GB)
