How to de-activate Octane for Poser ?
calvados
I usually switch machine of Octane for Poser.
But new SSO system is quite abnormal control,
I can't use one machine with Octane for Poser, it inform another machine is activated.
Deactivate button of Octane for Poser dose not work.
How can I switch Octane for Poser ?
Use the latest version of the plugin (3.1.1.74 from viewtopic.php?f=45&t=42585&start=440) - which will allow you to access the authentication window from the OctaneLive panel on both your systems and authenticate/deauthenticate as needed. You could also try de-authenticating via the website.
calvados
Thank you for your quickly support.
I will !
Octane Website inform that "de-activated", but 3.0.1.73 Plag in inform another site Activated.
May be dose not sync information.
Are BOTH the Poser plugin and Octane Standalone licenses showing "Deactivated"?
calvados
No, Only Octane for Poser.
Octane Stand alone is work well.
calvados
I tested your informed version.
May I ask you, this version say "Sign out Octane Account from this machine", this mean include Octane Stand Alone?
I wish account sign out from Octane for Poser only. Dose not include Octane Stand Alone.
I feel that afraid of trouble, therefore I dose not click sign out.
calvados
I found that case of shutdown Poser on another machine, License accepted.
License of Octane for Poser is authorized at Poser Start Up ?
It is very inconvenience, because I must consider about start up sequence of Poser with Octane Render.
I offen switch rendering machine and posing machine, because Ocnate dose not support Poser Rendering Queue.
I am unclear from you comments if the plugin is working or not for you now. If you have ONE Poser plugin license and ONE Octane Standalone license, you cannot run the Poser plugin on one PC whilst Octane Standalone is running on another PC - you would need to log out of Octane Standalone on the other PC before you could run the Poser plugin on the first PC. This is actually more flexible than the original licensing where you would need to de-authenticate prior to switching a license between PC's.
calvados
I have 3 Octane Stand alone licenses and one Poser License.
And I have 2 Poser Licenses, I switch those machines.
I render Poser sense with Octane Render, I made another sense by another machine.
And after Rendering by Octane, I change Octane Poser License and Render new Sense by Octane.
In this case, Current License System need YoYo Poser.
I'm sorry, but this is not clear. Are you able to clarify which licenses you have pls?
Return to “Poser”
