Black render
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
jamestmather
HDRI scene - worked fine last night then suddenly went black. Reimporting the scene into a clean max and resetting a new camera did the trick. This morning loaded up the scene and black screen again. If I come off the camera and render a perspective viewpoint it seems to be fine (albeit with some exposure adjustments). What am I doing wrong?
azen
First of all, apologies for the belated response.
If this is a bug, there may be some issue with loading the HDRI on start up. Please confirm your CUDA driver versions, and what version of the Max plugin you are using so we can be sure.
These kind of minor bugs tend to be fixed as a result of larger scale refinements that occur between releases. Please let us know if this issue persists in the latest version.
Azen
Return to “Bug Reports”
