Using both versions v2 and v3 possible ?
thekwen
Hello,
I need to use both versions of octane with 3dsmax, v2 and v3.
Usually for different versions of the plugin i juste reinstall the plugin version i need.
But now that standalone core has 2 versions, i'd like to know if there's a way to work on both versions of octane V2 and V3 ?
THx
Kwen
azen
If you have a v2 and v3 standalone installed, you will be able to reinstall v2 and v3 plugins over each other in the manner you are accustomed.
Be sure to have the 7.5 CUDA toolkit installed, otherwise, you will have issues with v3.
Azen
Return to “Autodesk 3Ds Max”
