Hello !
Since the last update to the C4D plugin, the volume objects won't show up in the picture viewer, even with forcing the live viewer update via the object tag.
Scenes that were working fine the day before have the same issue, with the exception of one that is using a cached turbulence fd simulation..
Any ideas ?
I'm using C4D R16 on 10.11.3 OS X.
Volume objects not showing up in picture viewer.
C. RAM Capacity (i.e. 6 GB)
- Attachments
- volume.c4d.zip
- (73.11 KiB) Downloaded 261 times
OS X 10.11.3 | 2xGeforce GTX Titan X (Pascal) | 2 x 3,33 GHz 6-Core Intel Xeon | 32GB
There is a glitch and sometimes it happens. Try add a few more before volume objects, object tag will not help.
And... is there a workaround, or is it an issue that will stick with this version ? Also, I'm not quite getting what you're suggesting I should add to the scene ?
Anyways, thanks for the quick heads up !
It's mostly working on me. I don't know why behaves different. Maybe about C4D and object generation. So i can't give any advice but i'll try to fix for next version.
I tried with R17 version of c4d with no luck as well.
Do you know if it's possible to downgrade to the previous version of the beta, or is there is a known ETA for the next version ? I would go back to V2 but no volumes back then, and sadly I can't launch any render until the issue is fixed..
F.P.
F.P.
Can you try with this version?
viewtopic.php?f=85&t=53989&p=278066#p278066
I'm unfortunately unable to test this version as it is R17 only, which I don't have access to right now..
Edit: I dropped by the office to try with the R17 version but for some reason the plugin don't even bother to show up in the plugins list, I also tried on another computer to be sure, with the same issue (both are updated with the latest CUDA version).
Please find 3.01.1 version to test it.
- 14bmwc780nike
- Contact:
I can confirm. Now we wait.Supranutz wrote:Hum, seems that version 3.01.1 is still unavailable for OS X..
H: C4D 2025 | Asus ProArt X870E-CREATOR | Win 11 64bit Pro | AMD R9 7950X3D 4.2z 16-Core | 96GB | 3070ti/3090
W: C4D 2025 | Asus WRX80E-SAGE| Win 11 64bit Pro| AMD TRPRO 5965WX 24-Core | 128GB | 3090Ti
Marcus | 3dconge.com | @RockingThePIxel
