Hi, I would like to ask if I am missing somethink. I composite Multilayer from modo and Beauty did not match multipass compositing. Should I add some other passes?
https://www.dropbox.com/s/o1s8wphm7vvya ... 4.png?dl=0 Compositing in Nuke
https://www.dropbox.com/s/p1imt9azi466x ... 5.png?dl=0 Same problem in After Effects
Multipass Compositing
- stratified
You are using the correct set of render passes.
Are you using linear colour space? I see that the file is called 'phones tonemapped.exr". Make sure that you have the tonemapping curves set to linear, gamma to 1 and no vignet.
cheers,
Thomas
cheers,
Thomas
