Reflection Catcher
maepopaxe
Hey Guys,
is there any way to implement a Reflection Catching Material, similar to the shadowcatcher? Maybe with the option to exclude direct environment Reflection.
I really need it every day but always need workarounds for this.
Cheers, Max
calus
You're supposed to use the render layer reflexion pass for that.
(basicaly the Octane render layer pass system is an evolved shadow catcher)
Pascal ANDRE
maepopaxe
yah, but how do you bump out direct environment reflection?
calus
You don't use the good pass (don't use "reflection direct" or "reflection indirect" pass),
use the "layer reflection pass" in the "render layer passes" group, it only catch reflections coming from the object in the actif layer id.
This pass IS a reflection catcher ! ;)
viewtopic.php?f=51&t=44267
Pascal ANDRE
maepopaxe
Cool, thanks for the tip.
But I whis there was a way whithout compositing. So u get a beauty with alpha including groundreflection with alpha and shadow as png.
maepopaxe
As an Examle,
here i attached a PNG from Autodesk VRED. Environment, Groundplane with shadows and Reflection. No direct environment Reflections. Premultiplied alpha. You just Drop it on any Background.
Examle
Examle
