Substance PBR Live DB Preset
mpaquin
It looks like the Substance PBR material is missing from the Modo Presets. I think the most recent version of the Live DB for modo is from January. Is there an updated DB hiding somewhere or has the Substance PBR material not been added yet? Is there a way I can manually export it from Octane Standalone and add it as a preset for Modo?
Pls see 3:45 min at https://youtu.be/P2JjcrXNQ6U for how to do this with the NodeGraph node. Pls note there is an issue with the NodeGraph node used on NON-Live Geometry Update meshes, which will be fixed in the next release of the plugin - so make sure you tick the Mesh Live Geometry Update property.
mpaquin
Thanks Paul. I appreciate it.
Return to “Foundry Modo”
