octane on 10.6.6
grod
I have been trying to test the dem version on my Powerbook running 10.6.6 and using a NVIDIA GeForce 8600M GT.
I installed the cuda 3.0.14 developer driver, but when I launch Octane I get the message:
"Octane Render 1.022 beta 2.2 cannot be opened..."
"Check with the vendor..."
This is the report:
Process: octane [322]
Path: /Applications/OctaneRender 1.022 beta2.2 Demo.app/Contents/MacOS/octane
Identifier: org.refractivesoftware.octanerender
Version: ??? (???)
Code Type: X86 (Native)
Parent Process: launchd [107]
Date/Time: 2011-02-16 23:51:30.778 -0500
OS Version: Mac OS X 10.6.6 (10J567)
Report Version: 6
Interval Since Last Report: 1025424 sec
Crashes Since Last Report: 8
Per-App Crashes Since Last Report: 5
Anonymous UUID: 086C0F51-C094-4B7E-9BFB-09477C31AD46
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0
Dyld Error Message:
Library not loaded: @rpath/libcudart.dylib
Referenced from: /Applications/OctaneRender 1.022 beta2.2 Demo.app/Contents/MacOS/octane
Reason: image not found
Binary Images:
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
Model: MacBookPro4,1, BootROM MBP41.00C1.B03, 2 processors, Intel Core 2 Duo, 2.5 GHz, 6 GB, SMC 1.27f3
Graphics: NVIDIA GeForce 8600M GT, GeForce 8600M GT, PCIe, 512 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8C), Broadcom BCM43xx 1.0 (5.10.131.36.1)
Bluetooth: Version 2.3.8f7, 2 service, 19 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Network Service: AirPort, AirPort, en1
Serial ATA Device: Hitachi HTS542525K9SA00, 232.89 GB
Parallel ATA Device: MATSHITADVD-R UJ-867
USB Device: Hub, 0x0409 (NEC Corporation), 0x005a, 0xfd100000
USB Device: Hub, 0x05ac (Apple Inc.), 0x9122, 0xfd110000
USB Device: Hub, 0x0424 (SMSC), 0x2504, 0xfd113000
USB Device: Apple Cinema HD Display, 0x05ac (Apple Inc.), 0x921e, 0xfd112000
USB Device: Apple Keyboard, 0x05ac (Apple Inc.), 0x0220, 0xfd140000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0230, 0x5d200000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x5d100000
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x1a100000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x820f, 0x1a110000
Any thoughts?
Maryus3D
I have octane 1.022 on my hackintosh (i5 and GTX 285) with 10.6.6 CUDA ToolKit 3.0 and CUDA driver 3.2 and it works flawless.
Uploaded with ImageShack.us
Aenima
Dyld Error Message:
If im not wrong you must set permissions. Start octane from terminal then you will se more info.
W10 x64 32GB, EVGA GTX960 - EVGA GTX1060 - OSX 10.12.5 - CORE I5 3.4GHz
grod
Thanks all, I think that my system was having issues with the 3.2 toolkit.
I installed the 3.0 version and it's all working now.
going to start doing some test renders :)
-g
