This happened to me twice today on 2 different machines. 1 on OS X R15 and 1 on OS X R17...
Doing a fresh install for a client. Installed C4D Plugin V3. No Otoy login screen. When I go to account tab there's just a logo and no option to log-in which is understandable because it should have prompted me on startup. Standalone works though. The solution in both cases was to install the latest beta. After installing, the account page then has an option to enter your license name and password (The old way.) After that process is complete, the NEW login window then appears and you can login. If you then install the full version (not beta) then the new account log-in screen appears as expected. 2 times today. 2 different machines. Has to be a bug.
C4D V3 Commercial Version Login Issues
- creativebloke
- Contact:
I am getting the same thing,I have two licenses for C4D, first machine uses new system just fine (it was an upgrade of Octane), however the second machine which is a clean install, the standalone works fine, but the plugin pops up the settings windows where the login used to be. Have deleted credentials a few times but with no luck
twitter = creativebloke
If you're new user or make a clean install of C4D so propably you saw this error
This is my mistake! It's shame on me because i forgot to remove this part from plugin. I hope that you understand the condition to make a very quick release under lot of user's critisms.
Workaround is to extract this file to C4D's preferences directory.
or running older an Alpha version and giving old plugin license numbers. At the end this required file will be created.
Empty Account/Password!!!
Initialization error!!!!
- Attachments
- oct.zip
- (678 Bytes) Downloaded 278 times
Have to give everyone a heads up on my "solution" to the issue. The client had 2 combo licenses they just purchased. In the process of doing the "fix" by installing the beta, it activated the "standalone." That's usually how it's supposed to work. But when you uninstall the C4D beta and install the full version of C4D V3 to activate via the new login process, it works but uses the second standalone activation. This means you have one computer with 2 standalones activated. So the second computer that I went to install would just throw up errors cause there were no more matching standalones.
So I went back to the first computer to de-activate the standalone via the logout option, but it would only deactivate the last version I activated. So then what? There's no option online now to deactivate without emailing customer support and just waiting. I then spent an hour and a half going between machines, activating and deactivating via the C4D beta again. Plugin was still not matching the standalone correctly and I still had one activation that wouldn't go away. Finally I went and installed the beta standalone version and was somehow able to deactivate. Then go to computer number 2, install the beta C4D V3, register, install the full C4D V3, and just hit buttons until combinations of activating in different offices lined up and matched.
This is hair-pulling frustration. I know the launch has been a lot of work and there will be issues, but I really think they need to reconsider the online option to deactivate so we don't get screwed in a pinch. Sometimes you can't wait for offices on the other side of the earth to open and get your support email. There's got to be a better way. Preferably the old way. What happens if your computer takes a dump and you don't have the option to deactivate? Is email the only way?
aoktar wrote:Hi,
If you're new user or make a clean install of C4D so propably you saw this errorEmpty Account/Password!!!
I didn't get that error. It acted like everything was fine until I hit render and then it told me to go to the Account tab and enter my activation. But that tab no longer has anything in it but a logo.
And no, I totally don't mean that as a criticism of you. I know you're working your ass off on this plugin and it's very much appreciated. Just wanted to bring up the issue in case anyone else encountered it.
We talk very highly of you on our podcast (Brograph) for all the work you do.
HI
I have a PC
I try the demo v.2 for company, and decide to buy octane V.3.
I try to install and i run it in C4D,
But it popup a window
"Octane Render couldn't be intialized, please check your account and internet connection."
I click "OK" then popup another window
" Empty Account/Password!!!
Please check your account setting in Octane
Settings-->Settings-->Accpount! "
I go Settings->Account, There only have a logo.
I try to put the "oct.dat" to C4D's directory. Then same problem.
I try to put the "oct.dat" to C4D's Plugins/c4doctane. Then same problem.
Pleas Help.
How can I do?
I have a PC
Pleas Help.
How can I do?
@fosterf: can you try this build?
https://render.otoy.com/customerdownloa ... .1-win.zip
I put "oct.dat" to "\\AppData\Roaming\MAXON\CINEMA 4D R17_8DE13DAD\prefs"fosterf wrote:HI
I have a PC
Pleas Help.
How can I do?
Now is good..
Thank you
- creativebloke
- Contact:
the new release (R1.1 - 25th May) fixed the bug straight away - thanks aoktar
