[SOLVED] Photoshop Tiff and Alpha channel
oMeGa
Hi guys! I've a problem with Photoshop CC 2015 and Octane v2.25-R4 c4d plugin.
First i try to search on this forum but without luck, and of course on octane pdf but don't speak to much on alpha channels. So...
I try a make a simple texture, essentially is a white background and some text in black, and want to use as a alpha channel for doing stuff on octane node manager.
Now.. i need to make the text as alpha, i have tried exporting in .png format without the alpha channel, and octane recognize alpha channel of the .png but when i switch the mode to float or normal it make rectangular boxes around the text??? And this is a second issue.
The first issue is i can't make a tif with alpha and let octane recognize it as an alpha image.
The workflow is:
Photoshop, White background, black text, then select the text and save as an alpha channel, save in .tif format without layers, and with export alpha channel checked. (Grey/8).
Then when i import the image in octane and switch the mode to alpha it simply doesn't work.
(I don't have provided any screenshoot for time-saving, but if u think is useful i can post it.)
Thanks guy, hope anyone can help me with this little issue.
oMeGa
After various trial and errors, i've found what is the problem, and want to share how i solved the problem.
The problem is 8bit image texture, i have used 8bit greyscale image and octane don't recognize alpha channel.
So i saved .tif from photoshop in 16bit greyscale and it works!!! Let's the alpha madness begins!!!
Hope this can help a beginner like me on this forum!
Cheers
TonyBoy
Great tip, thanks! The 8 bit trap is perfect for newbies because 8 bit is economical and the most common. I see where some displacement maps are best at 32 bit.
