Network rendering issue.
lideborg
Hey!
Finally managed to setup everything at work so i brought my old workstation to my new work to use the GPUs from that one.
Both machines has 2.25 standalone and c4d plugin installed.
When running the "_run_installed_daemon" i get this dialogue http://d.pr/i/11O2u and the computer won't show up in the network setting on my maincomputer. Strange thing is that when i was using the beta 2.1 earlier and tried it showed up in the network setting, only it said it needed to be the same version. So then i got 2.25 on everything and nothing seems to work, installed the beta again and same there, does not show up.
Any takes on what it might be?
Hi lideborg,
sorry but I cannot understand the error message :(
Correct, Master and slave must always be of the same version number.
Have you tried by disabling the Firewall?
lideborg
bepeg4d wrote:Hi lideborg,
Firewall disabled, this is the errormessage on the other computer, might make a bit more sense?
http://d.pr/i/16mD0
Hi lideborg,
I cannot see any error in the second screenshot :roll:
By the way, are you able to start v2.25 standalone on the slaves?
lideborg
That's so strange! I get the same dialogue-windows on both windows machines now, which means no error. Can start up 2.25 standalone on both of them, no error
lideborg
Just installed the R3 vserion instead of the R4 and it showed up! Well problem solved!
