OctaneRender™ 3.0 for Houdini™ - production build 3.00
juanjgon
Hi! This is the first stable release of OctaneRender™ 3.0 for Houdini™. This 3.00.20.0 build is available for the Houdini 13.0/14.0/15.0/15.5 last production builds for Windows x64, Linux gcc4.8 and OSX 10.10.
This plugin is also compatible with Houdini 15.5 Indie. In this case the plugin will have a 1080p limited resolution while rendering sequence, and the scene export and cloud rendering features disabled.
Of course, this is just the beginning of the v3 development cycle and there is more to come ;)
New features
A list of all the new features is provided here: viewtopic.php?f=33&t=51679
The plugin manual is going to be updated in the next weeks to cover most of the changes. http://render.otoy.com/manuals/Houdini/
Licenses
To run 3.00 you need a v3 license. You can still run the 3.00 alpha and beta versions with a v2 license until the end of May. The current plan is that 3.00 alpha and beta versions will stop working on 1st June 2016. If the roll-out of non-beta 3.00 versions for all plugins that had a 3.00 beta version takes longer than expected we will extend this grace period.
With v3 licenses you can still use 1.xx and 2.xx versions of Octane, but v3 licenses cannot be deactivated via the OctaneLive web interface anymore, since they will be deactivated automatically by closing Octane or by signing out an offline authentication.
For more details about the new authentication and license system, please read the new features post.
CUDA requirements
Due to a CUDA compiler bug we had to switch to CUDA 7.5, which means on Windows and Linux you may need to update your NVIDIA graphics driver to a current version which supports at least CUDA 7.5. On Mac OSX you may have to update the CUDA driver for Mac to a current version supporting at least CUDA 7.5.
Known issues and limitations
We noticed that deep pixel rendering crashes the render kernels on Maxwell GPUs (compute model 5.x) if the scene contains volumes. We are still investigating, but it looks like a CUDA compiler bug. If it's a compiler issue, we will try to work around it, but it might take a while until we have found a solution for the issue. Also in the Houdini plugin we have an issue with the LiveDB materials window on OSX, that we are investigating.
Just after this first release, we will continue working in some missing features, like support of particle system using the new Octane sphere primitive, the load/save render states, support (or find a workaround) of custom attributes, etc.
Production release 3.00.20.0
https://render.otoy.com/customerdownloa ... _Win64.zip
https://render.otoy.com/customerdownloa ... _Linux.zip
https://render.otoy.com/customerdownloa ... ni_OSX.zip
Production release 3.00.20.0 DEMO VERSION
https://render.otoy.com/plugindownloads ... 4_DEMO.zip
https://render.otoy.com/plugindownloads ... x_DEMO.zip
https://render.otoy.com/plugindownloads ... X_DEMO.zip
Standalone version for the network rendering nodes
https://render.otoy.com/customerdownloa ... 00_win.exe
https://render.otoy.com/customerdownloa ... _macos.dmg
https://render.otoy.com/customerdownloa ... _linux.zip
dinf
Hey Juanjo,
thanks for this build.
If this is to use with v3 license only and Houdini Plugin losts it beta state, when are we able to obtain the full v3 plugin license?
Or did I get something wrong?
Cheers, D.
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
juanjgon
You should be able to get the v3 licenses right now, in the OTOY site store.
https://home.otoy.com/render/octane-render/purchase/
Angelos
Thanks!
But how to update?
There's no option for Houdini Plugin update.
and Houdini shows error:
dinf
juanjgon wrote:You should be able to get the v3 licenses right now, in the OTOY site store.
Thanks Junajo!
Me to Angelos. I'll wait and get back to the upgrade a bit later.
juanjgon
Ok. Yes, I can see here also that there is no option to update the Houdini plugin. I'll send an email to the NZ team to fix it.
I'll let you know when I know something more.
dinf
juanjgon wrote:Ok. Yes, I can see here also that there is no option to update the Houdini plugin. I'll send an email to the NZ team to fix it.
Great, thanks!
WhyGee
Will upgrading just the standalone for now allow us to use the new build with the old license?
juanjgon
WhyGee wrote:Will upgrading just the standalone for now allow us to use the new build with the old license?
I don't think so. You are going to need to upgrade the plugin license.
Anyway remember that at least this week you can use the Octane 3 beta build using the old 2.2 license without problems. The changes from the last beta to the final release are minimal, and only related to the licensing system.
WhyGee
I meant until the houdini plugin upgrade is available in the shop menu. Of course I'll upgrade both :)
