3ds max 3.0 2 3.10 Particle
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
nikostap
Don't works movable proxy for particles when particles deletes from scene.
Don't works animated bitmap "Syns Frame to Particle Age" with particles.
p.s
previously worked
Could you give me this scene?
nikostap
yea sure.. take it
https://drive.google.com/file/d/0Bx6bhf ... sp=sharing
max 2016
now, a long plane not deletes from scene)
Either one works, then another, then all is not updated.
Thank you. Will check it on Monday.
What is the last plugin version that worked with this for you?
nikostap
i fogot map..
Wave.rar
animate maps
(382.86 KiB) Downloaded 272 times
nikostap
ohh.. i dont remember(( Maybe the first or second version 3.0 . I can check it, and then write u.
Works OK for me for both: "movable" particles disappear when needed, and the bitmap is animated.
nikostap
How about a small long plane? In your video, is still in scene and not deleted.
bitmap anim work i know, but it not synchronic by event. Synchronization with particles by event not work!
Thats is Scanline
[youtube]https://youtu.be/hiUT4v2whyg[/youtube]
And that is Octane
[youtube]https://youtu.be/0b9PeU8vdAc[/youtube]
On Your Video
Yes, Octane image textures do not support the particle age sync currently, thank you for pointing it out... The "Sync Frames to Particle Age" option you've enabled - is an option of standard 3ds Max Bitmap texture.
I will investigate a ways to implement it for Octane textures in future versions...
nikostap
Thanks Jim, u're the best)
Return to “Bug Reports”
