after a long period, a new demo is available.
For changes, please read the history.txt file because i don´t like to add 300+ lines
But i have to say, the whole plugin is nearly new in all sections.
I will post only some major changes.
- The most wanted change is the support of Particles. For now only internal shapes are supported. Different colors aren´t working because Octane doesn´t support it.
All internal shapes are uv mapped. - Shaderball preview with nested compounds is supported.
 - Image saving is multithreaded, you can also save different formats at once.
 - All shaders are rewritten, so they look different from the old release.
 - Instance support.
 - Object Layer is included. Valid values are "Ray Visible" and "Shadow Caster", which you can set under the Visibility Rendering PPG
MANUAL
- The on-line manual is available at http://render.otoy.com/manuals/Softimage/
- Please follow the installation instructions in the on-line manual.
- This version requires video driver 337.xx or higher..
face
