Check materials every frame
Heerko
I was wondering, at render time you can check or uncheck "check materials every frame"
Should I uncheck this if I have no animated materials? Or does this mean something different?
I tried searching the manual and forum for this, but couldn't find anything.
Win 10, 4090 FE, AMD Ryzen 9 7950X, ASUS ROG Crosshair X670E Hero, 2X Kingston Fury Beast KF552C40BBK2-64, Seagate FireCuda 530
Hi Heerko,
if you have an animated material you must leave the option active, otherwise the animation is not catched. On the other side, you can untick the option and save a bit of time every frame if your scene doen't have animated materials ;)
Note that the hdr environment is not affected by this option.
Heerko
Thanks Beppe :)
Does checking mean, loading in the materials every frame? Or does it simply check for keyframes or something like that?
Heerko wrote:Thanks Beppe :)
Plugin does standard material checking procedures when this options is enabled. Otherwise will not control check and recreate these for each further frames. It should not make any difference when you don't have animated materials.
Heerko
Thanks! :)
