Displacement causing irregular Render Crashes
artshaman
I'm having trouble with rendering and displacement. Sometimes a setup loads in the Live View no problem and sometimes it just crashes. It seems to correlate with the large displacement textures I am using.
I'm using a Mac, 96gb ram, Titan X,
This is my Log:
Export materials time= 148785.84 ms
Collect objects time= 1.534 ms
Mesh creation time = 656.336 ms.
Triangles:42k Disp.triangles:1.69m Hair count:0 Mesh count:32
CUDA error 2 on device 0: The API was unable to allocate enough memory to perform the requested operation.
-> failed to allocated device memory
device 0: failed to upload data texture 7 of context 0
<<< Render Failure >>>
VRAM used/free/max:917Mb/115Mb/12Gb
Total export Time = 250745.413 ms
Any help would be really appreciated. Considering I have 12Gb of VRAM available why is it using so little?
Thank you in advance! :)
pffff. 148 seconds for material export. What are you doing man?
artshaman
I am rendering images for VERY large print resolution. I have all other applications closed.
Why would it be using such a small amount of the VRAM in these cases?
My images are large, but I can't make them smaller as I am rendering for very large print size and need the resolution. Similarly if I reduce polygon count the image quality noticeably suffers.
Thanks for your response
I think your images are not fitting to VRAM and some of them are filling out-of-core. Can you try to increase out-of-core RAM?
artshaman
I turned that up to 64Gb.. whats GPU head room? Would that effect anything.
Thank you
