Bridges between OctaneRender and Photoshop - PS Plugin MIA?
linvanchene
Placing the answer to the question in the Off Topic Forum.
The idea of this thread is to provide a quick overview of
- The DAZ Studio 3D Bridge
- Exporting to Photoshop for the OctaneRender plugin for DAZ Studio
- Photoshop compositing extension
and last but not least to ask
- what happend to the OctaneRender for Photoshop plugin that was announced in 2014?
Notiusweb wrote:Linvanchene, is that a direct export to Photoshop with Daz, how do you like using that? Does it work somehow with the OcDS plugin also?
The DAZ Studio 3D Bridge Tab
It captures the DAZ Studio viewport as a 2D image and sends it over as a layer to photoshop.
compare:
http://docs.daz3d.com/doku.php/artzone/ ... bridge_tab
-> When you use "Render to New Layer" it actually uses the selected Render Engine either Iray or 3Delight with the selected settings to render an image and send it over to photoshop as layer.
Unfortunately OctaneRender for DAZ Studio has its own viewport therefore you cannot use that feature.
Sending maps from the OctaneRender for DAZ Studio plugin to Photoshop
If you have assigned a material to a surface in OctaneRender for DAZ Studio and now want to quickly edit that map in Photoshop you can do that.
- Make sure in the OcDS preferences tab the path Image Editor points to Photoshop.exe
- Now select an image map in either the NGE or the materials tab and select:
External Editing / Open in Editor
- A copy of the map will be created in the original save location
- edit the map in photoshop
- when finished click the refresh button next to the map in OcDS to load the altered version
With OctaneRender 3 support for compositing Octane render passes in Photoshop and loading multi-layer OpenEXR files (16 and 32 bits) was added to OctaneRender standalone.
compare:
viewtopic.php?f=33&t=51679
OctaneRender plugin for Photoshop
But what exactly happend to the full OctaneRender for Photoshop plugin that was announced in August 2014?
https://home.otoy.com/otoy-expands-octa ... er-engine/
One idea for the OctaneRender Photoshop plugin was that you could paint on maps in Photoshop and then would see the updates in almost realtime in the OctaneRender viewport while painting.
A video preview is still up on the official Otoy youtube channel:
-> Does anyone know if development of the photoshop plugin for OctaneRender has been stopped or if someone else will pick up development again?
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
Notiusweb
Wow! Thanks! You are amazing Linvanchene!
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
I could be wrong - but the Photoshot plugin mentioned in the Otoy press release might refer to the Photoshop Compositing Extension (viewtopic.php?f=33&t=51679).
The video you posted appears to be a specific OctaneRender for DAZStudio to Photoshop link being developed by t_3, which I don't think was ever completed.
linvanchene
face_off wrote:I could be wrong - but the Photoshot plugin mentioned in the Otoy press release might refer to the Photoshop Compositing Extension (viewtopic.php?f=33&t=51679).
As far as I can put things together based on official forum and blog entries:
- t_3 started the OctaneRender for DAZStudio to Photoshop link as a side project and posted a video of it on his personal Vimeo page
OcPS GTC demo 1
- At some point t_3 mentioned that work on the photoshop bridge plugin is only to continue after all the DAZ Studio plugin work is done
- Nevertheless it seems Otoy liked the idea and then announced an official photoshop plugin
The video and screenshots in the Photoshop plugin announcement post and the official Otoy youtube page are identical to the video originally posted on Vimeo.
- After this point it was not clear who exactly was supposed to develop the photoshop plugin with map painting preview in OR viewport further
-> some people hinted at that t_3 only might have been responsible for the first concept version but that someone else would then take over
But now it indeed seems that the bridge project that included map painting preview in the OR viewport was cancelled.
I am not really sure if the Photoshop Compositing Extension is a result of the work already done or if it was developed completely independent of the bridge project by t_3.
Goldorak
We are exploring a full PS plugin after 3.0 is out. The compositing extension is an interim step in that fired direction.
Return to “Off Topic Forum”
