Texture Anti-Aliasing
Mules
Does the Octane Render for Modo use some kind of anti-aliasing on image maps ?
Would be nice to add some anti-alias options, of turn anti-aliasing off, in an image node.
Greets,
Mules
I'm not completely sure what you are asking here. If you have aliasing on a texturemap, I would have thought that meant the texturemap was too low rez? Also, check out the Kernel->Filter Size - it will assist with anti-aliasing the resulting rendered image.
Mules
Hi Paul,
It's the equivalent of these setting (see attachment) in Modo.
These are settings on a texture layer.
I'll also check the filter size setting you mention.
m,
Thanks for the screenshot. Octane doesn't have individual image map filtering.
Return to “Foundry Modo”
