PHOENIX FD can use it?
Goldrakes73
Hi! It's possible use Phoenix fd plugin in max with Octane? thanks a lot.
Marcello
azen
Yes, Phoenix should work with Octane 3. Since Octane 3 is still in Beta, there may still be some issues with support for this. If so, please detail the issues you are currently, to allow for more effective troubleshooting on our end.
Azen
Goldrakes73
Thank you Azen! I cant wait Octane 3! )))) :P
brettg19802
Thank goodness!! Been waiting for Pheonix FD compatibility!
coilbook
What about fume fx
azen
coilbook wrote:What about fume fx
Fume FX falls under the same category as Phoenix. The aim is for all plugins to be usable with the Octane plugin (owing to an overhaul in the construction of core as well as the plugins). In short, Fume FX will be compatible with Octane for 3ds Max.
coilbook
Someone said Phoenix fd does not create vdb files will we be able to use it for 3ds Max to render smoke foam bubbles.
coilbook
haze
coilbook wrote:Someone said Phoenix fd does not create vdb files will we be able to use it for 3ds Max to render smoke foam bubbles.
(In tandem to FumeFX compatibility) we're hoping to make use of the PhoenixFD SDK for the upcoming Max plugin release. This is currently in progress.
wxyz
Great news!
Return to “Autodesk 3Ds Max”
