v3.0b1 - 3.5 [BETA] material bugs
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
crackfox
connecting nodes in some cases makes mat editor go haywire:
- once a material goes screwy deleting connecting nodes leaves the connections in place (floating red wires).
- also once a node is connected to a slot, it cannot be connected to other slots.
- its generally unresponsive
this happened while i used the uv scale node and was only fixed by restarting max.
i tried to reproduce it but cannot find a pattern.
max 2017, win7 64bit.
azen
Thank you for bringing this to our attention. It could possibly be an issue with 2017 support potentially. I will attempt to replicate and identify the pattern. Hopefully it should be resolved in the next release.
Azen
Return to “Bug Reports”
