Displacment + Texture Emission with alpha 10.1
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
proundkontra
Hi
I might discovered a bug. Otherwise i just messed up something.
Since i switched from Alpha 6.3 to 10.1 i have a issue. When i have a mix texture with two materials (1. diffuse in which a texture emission node is pluged in 2 .glossy) and a displacment node pluged in the mixmaterial as well
it won't render texture emission anymore. Even when i bump up the power to a insane amount.
I switched back and fourth from 6.3 to 10.1 and is't always the same.
I run c4d r17 with octane stadalone 3.00 alpha_10
Cheers
Niko
nikoeriksson.ch| i7 6x3.5 Ghz | 64GB | 2 x GTX 1080Ti Hybrid , 1x GTX 980Ti Hybrid | Win 10 | C4D R19.068 | Octane Render Plugin C4D v3.08.4
scene please
proundkontra
Hi Aoktar
Since my scene is quite havy i upload a testscene "grain" uploaded a while a go.
While i was looking for a answer on the forum i found that scene.
you can see the error verry good with that scene.
texturetest.c4d.zip
(872.08 KiB) Downloaded 228 times
Hi proundkontra,
it's not a plugin bug, but it comes from the latests SDKs, I have already sent a scene for this and another issue to the devs, thanks for pointing it out ;)
proundkontra
Hi Beppe
Your welcome
Return to “Bug Reports”
