REDUCE NOISE
Interfaces
hi,
this is one of my first indoor picture
I would like to reduce noise DL Mode -> Diffuse, I fail after several attempts.
Do you have any solutions?
THANKS
Hi Interfaces,
first question, are yours lightspots recessed in the ceiling?
If yes, slightly move them down until they are completely out and you should see a big difference in term of noise :roll:
Then switch to Path Tracing, set the GI Clamp at 10 or below with a bit of Choerent ratio (between .35 and .5)... the render should be cleaner, brighter and faster then DL Diffuse ;)
With v3, you can also increase the parallel samples to speed up the calculation even more ;)
Last question, is the Gamma of the ies file set to 1?
Interfaces
Thanks for your answers, i will test
sirmarkus
Blender + ( i5 + Asus Gryphon + Asus GTX 760 DirectCU II + 8 GB)
Elvissuperstar007
Return to “Works In Progress”
