No geometry in camview BlenderOctane
brunoh
Hello,
I have no geometry in my render from camera :!: .
I use :
Blender_Octane_Edition_9.8_2.76
Octane_Server_DEMO_2.24.2_-_9.8
Thanks for the help.
b.
renderproblem.blend
(509.5 KiB) Downloaded 155 times
abreukers
Hi Brunoh,
I opened your file and it does have some geometry on my viewport:
I also see here you are using the demo version.
The demo has some restrictions, maybe check if your scene resolution is too high for the demo to accomodate.
brunoh
Hello,
Thanks for the reply,
I meant "no geometry in camview when you render with octane in the 3dviews."
If you press ShitZ over the camview,in my case it doesn't render in cam view,but it works in persp view.
b.
abreukers
hi brunoh,
ah ok I see what you mean now. the camera should not be autofocused infinitely or have the focus distance of '0'. try entering a value for the focus distance that is longer than '0' because just like in real world cameras the object will be visible in camera only when the object exists between camera and its focus distance...
