v3 alpha crashes max
crackfox
connecting both bump and displacement while octane viewport is active freezes max causing it to crash.
turning it after they are connected displays the default colur gradient square.
azen
Thank you for the description. This should be enough for us to duplicate and locate the source of this issue. If the bug cannot be duplicated on this end, I would like to ask a few more questions.
Azen
crackfox
hi azen,
thanks for responding.
after i wrote i did a couple of hours of work and have not encountered the bug.
will keep you posted if and how it crops up again.
generally though the meterial editor is behaving very odd at times.
best regards,
azen
Thanks for that.
It could be possible that your issue is a symptom of Alpha stage instability. It is common for a number of miscellaneous minor fixes to accompany noted improvements/features/major bug fixes. The minor fixes for the next release will either fix your issue, or isolate it and thus make it easier to identify and eliminate outright. Either way, this shouldn't be a difficult issue to resolve. Any updates on your user experience would be greatly appreciated.
Return to “Autodesk 3Ds Max”
