Textures are not loaded with .obj
Forum for OctaneRender Lua scripting examples, discussion and support.
SamuliKuusisto1
I'm trying to build a scene and render it via script using lua scripting. Why textures are not loaded to the .obj file? I've tested the script with two different .obj-models, and the textures are loaded only to the other. The script:
rt = octane.node.create{ type=octane.NT_RENDERTARGET, name="Impl RT" } -- implicit in the root graph
mesh=octane.node.create{type=octane.NT_GEO_MESH, name="mesh1"}
mesh:setAttribute(34,"D:/Projects/visudevel/Octane/VT7/vt7.obj",true)
print(rt:getProperties().graphOwned, rt:getProperties().graphOwner)
daylightEnv=octane.node.create{type=octane.NT_ENV_DAYLIGHT, name="daylight"}
daylightEnv.setPinValue(daylightEnv,"sundir",{63.0,23.4,6.00,20,12.00,2.00})
daylightEnv.setPinValue(daylightEnv,120,0.5)
placement=octane.node.create{type=octane.NT_GEO_PLACEMENT, name="placement1"}
print(placement:getProperties().graphOwned, placement:getProperties().graphOwner)
transform=octane.node.create{type=octane.NT_TRANSFORM_3D, pinOwnerNode=placement, pinOwnerId=octane.P_TRANSFORM}
transform.setPinValue(transform,"rotationOrder",2)
transform.setPinValue(transform,"rotation",{-90,90,0})
placement:connectTo("geometry",mesh)
rt:connectTo("mesh",placement)
rt:connectTo("environment",daylightEnv)
print(transform:getProperties().pinOwned, transform:getProperties().pinOwnerNode)
-- create a panoramic camera in the camera pin of the render target
-- we need to specify both the node that has the pin and the pin itself
rt:setPinValue(198,{8192,2048})
pcam = octane.node.create{ type=octane.NT_CAM_PANORAMIC, pinOwnerNode=rt, pinOwnerId=octane.P_CAMERA}
pcam:setPinValue(228,3)
pcam.setPinValue(pcam,20,0)
pcam.setPinValue(pcam,87,true)
--[[pcam.setPinValue(pcam,133,{-19,410,-353})--]]
-- see if the file exists
function file_exists(file)
  local f = io.open(file, "rb")
  if f then f:close() end
  return f ~= nil
end
function lines_from(file)
  if not file_exists(file) then return {} end
  lines = {}
  for line in io.lines(file) do
    lines[#lines + 1] = line
  end
  return lines
end
lines=lines_from("D:/Projects/visudevel/Octane/VT7/vt7.txt")
function parse(line1)
    --[[file=io.open(filename)
    io.input(file)
    line1=io.read()--]]
    print("line:",line1)
    index1,index2=string.find(line1," / ", 1)
    print(index1,index2)
    name=string.sub(line1,1,index2)
    print(name)
    line2=string.sub(line1,index2+1,string.len(line1))
    print(line2)
    index3,index4=string.find(line2," / ", 1)
    line3=string.sub(line2,index4+1,string.len(line2))
    print(line3)
    index5,index6=string.find(line3," / ", 1)
    x=string.sub(line3,1,index5)
    print(x)
    line4=string.sub(line3,index6+1,string.len(line3))
    index7,index8=string.find(line4," / ",1)
    y=string.sub(line4,1,index7)
    print(y)
    line5=string.sub(line4,index8+1,string.len(line4))
    index9,index10=string.find(line5," / ",1)
    z=string.sub(line5,1,index9)
    print(z)
    return x,y,z
    end
for i=1,#lines,1
do
    x1,y1,z1=parse(lines[i])
    print(x1,y1,z1)
    pcam.setPinValue(pcam,"pos",{-y1,z1,-x1})
    print("D:/Projects/visudevel/Octane/VT7/vt7_"..i..".png")
    print(pcam.getNodeInfo(pcam).takesPinDefaultValues)
    print(pcam:getProperties().pinOwned, pcam:getProperties().pinOwnerNode, octane.apiinfo.getPinTypeName(8), pcam:getPinValue(20), pcam:getPinCount())
    octane.render.start{renderTargetNode=rt}
    print(octane.render.saveImage("D:/Projects/visudevel/Octane/VT7/vt7_"..i..".png",octane.render.imageType.PNG8,false))
end
jobigoud
1. Are you positive that the mtl file does reference textures? You should be able to open the .obj and .mtl in a text editor to verify.
2. Does it work when you add the mesh through the UI rather than a script?
3. Does the resulting mesh work if you run just the two relevant lines directly in the script editor?
mesh:setAttribute(octane.attributeId.A_FILENAME, "D:/Projects/visudevel/Octane/VT7/vt7.obj", true)
If the referenced texture was missing from the disk you would get an "Open file" dialog (even if loaded from script).
There are also global options under menu File > Preferences > Import > OBJ Import > Material types and Texture types. See whether some types are unchecked.
roeland
Note also that you can use the constants defined in the API to reference attribute and pins, for example octane.A_FILENAME in the code above.
Return to “Lua Scripting”
