2.43 opens then crashes when node is clicked. (OS X)
ednammour
Program opens fine -- seems to be communicating with OctaneLive account just fine. All other windows and nodes behave fine. Voxelizing OK. But...when I click the primary object node (the "click me" node) the program crashes.
(This does not occur with the 2.3 V5)
Any thoughts? Many thanks in advance.
Ed
OSX 10.6.6
2x3 GHZ Xeon
32 gigs RAM
Cuda 3.2.17
NVIDIA QUADRO 4800
i had got the same issue , for solving i had to reinstall the 10.6.6 Combo update in order to overwrite the nvdia graphic drivers with the apple's one and all now work perfectly.
i hope it's the same for you
hdri3d
i have the problem !
ednammour
Thank you so much for the suggestion, bepeg4d.
Unfortunately, reinstalling 10.6.6 combo did not solve the problem for me.
Grateful for the ideas though!
Best,
Ed
it's a bit strange that you could use the 2.3 v5 because it could run only with cuda 3.0.
have you also installed the cuda 3.2 toolkit?
ednammour
Thank you, bepeg4d. You are a genius!
I just installed the 3.2.17 CUDA toolkit, per your suggestion, and everything works fine. It would never have occurred to me to install the toolkit as I was focused just on the drivers.
A million thanks for your help!
Ed
