Hi All
Has anyone else experienced this?
You create a material in Standalone and then save out to LocalDB.
Then when you add the LiveDB Node inside Layout and import the material Layout just crashes.
I'm running LightWave 2015.3 and Octane 2.25
LocalDB Import causes Layout to crash.
As far I know the problem is that if you import a liveDB material twice, Layout crash. If you import the material only one time, it should work.
This is a known issue that is fixed now in the Octane 3 plugin. If at some point we release a new build of the Octane 2.2 plugin, I will fix this issue also for this version.
