Normal mapping broken since alpha V6..
Vejzovic
Normal mapping broken since alpha V6.. Or am I doing something wrong, maybe missing some new feature I should turn on..
gif upload
Rikk The Gaijin
How should it look like?
Also, depending of which application you generate the Normal Map from, you might have to check the Invert option in the Normal Map properties.
Vejzovic
HI !
It should look like the image below rendered in V6 alpha.. the upper image rendered in v9 alpha (v7,8,9 renders the same) It is the same scene with same settings.
Hi Vejzovic,
thank you for sharing this, the devs are now aware of the issue.
