OctaneRender™ for Blender 2.25 - 9.10 OSX [OBSOLETE]
Locked
The OSX version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed a crash when live-preview image is saved.
Installation:
DOWNLOAD
Blender Octane Edition - v9.10 OSX
DEMO is available..
Blender Octane Edition DEMO - v9.10 OSX
viewtopic.php?f=24&t=52329
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
EricSerpi
Thanks for your hard work JimStar.
But...Big problem with some of the imager settings,
they are only working in preview mode but not in render:
Gamma
Saturation
Highlight compression
Eric
Next version HERE.
Locked
