I'm surprised to find only one Octane ROP can be used in a scene. Is there a work around to submit multiple renders in a row?
Best regards
Filip
Multiple Octane ROPs in one scene
This is a limitation of the Octane 2.25 plugin. The last build of the Octane 3.0 plugin should work with multiple ROPs without problems.
viewtopic.php?f=102&t=52963
I've updated to Octane 3. I can now have multiple Octane_ROPs in a scene, which is great.
I've been trying to render out two Octane_ROPs frame after frame:
ROP_01 frame 1
ROP_02 frame 1
ROP_01 frame 2
ROP_02 frame 2
and so on. I can't get it to work right. The first two frames are created properly. Then rendering goes on, but nothing gets saved to disk or the two frames get overwritten over and over (I'll check if it's the one way or the other).
Is this something that could be fixed in the plugin?
ROP_01 frame 1
ROP_02 frame 1
ROP_01 frame 2
ROP_02 frame 2
Intel Core2Quad 9200 / 4 GB OCZ / Gainward 460 2GB
The problem is that while rendering in update mode the plugin only loads the scene in the first frame, to later update it along the sequence. This is not possible if several ROPs are running at the same time.
Anyway I'll check it again to see if at least could be possible support this feature reloading the full scene for each frame.
