OctaneRender™ for Blender 2.25 - 9.9 Win [OBSOLETE]
Locked
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • New 2.25 Octane core.
  • Fixed the region rendering crash.
  • Fixed kernel presets bug.
  • Improved region render mode efficiency (lowered the amount of network traffic).
  • Interactive session image is now automatically saved (if the image output path is set) every time the session is finished or reloaded.
  • A couple of minor fixes and improvements...
Blender Octane Edition - 9.9 (2.76)
Octane Server - 2.25 - 9.9
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.25 - 9.9
viewtopic.php?f=24&t=52329
Please, if you decided to report a bug:
- Don't post here the reports about how Octane engine works - use the Octane Standalone forum sections for that.
- Give a meaningful description about what you think is wrong and how to reproduce it (in addition to screenshots if any). I can't solve the "one screenshot" rebuses without any meaningful description...
- If you use Google-translator to post here - check please what you got before posting it, and edit it before posting. Ask your friends to check it if you don't speak English.
- If you like to discuss something about the plugin - create a separate thread, don't flood in these testing threads please.
Any meaningless or rebus-like "reports" here will be deleted, just to keep the testing threads clean - because these threads are directly used as the source for fixing and improving the plugin.
Next version HERE.
Locked
