Render region - how doe's it work?
Micha3D
I rendered an image over 2 hours and finally I found one material needs to be adjusted. I enabled render region and draw a rectangle and ... the whole image is rendered again. What did I wrong?
Ciao,
Micha
Win7 64 | Dual Xeon E5-2687W | GTX 1080ti 11GB + GTX 780 6GB | Rhino3D
Hi Micha - Render region is not working in Octane 3 at the moment - but is something Otoy hope to have working again shortly. You will need to use the Octane 2.25 version if you want to use Render Region currently.
Micha3D
Thank you.
Micha
Micha3D
Found a workaround - I create mesh sphere with a medium polycount around the camera and extract the mesh faces to get a few to my wanted region. I assigned a black diffuse material. So I get black render and only where I deleted the polygons I get my rendering back. Using it to rerender a wrong material of a little scene part.
Phil_RA
The bug Misha reported is an issue I get in Octane 2.25 too. I've had this for at least a few months now, I use 3DS Max 2014. In the standalone application I have not been able to repro this.
As soon as you change a material property, when you unpause the render everything will be re-rendered for a short time, and then only the region. It should not re-render the whole image, only the region.
Hi Phil - is this a problem in the Rhino plugin, or the 3ds Max plugin? If it's the later, you will need to report it in the 3ds max forum.
Return to “Rhinoceros 3D”
