slider in the displacement node [SOLVED]
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
calus
Height parameter slider of the displacement node is unusable:
Using the slider, the smallest value I can have after 0 , is 1274465727539543905552162262439952384.000
A good way to crash Maya is to use this slider while an IPR session.
It may be relative to a more general problem for octane attributes sliders which have the same soft-limit and hard-limit.
See here:
viewtopic.php?f=28&t=52220&start=17
Pascal ANDRE
k.a.schubert
Yeah attributes don't get a min/max set in this case, so the slider is unusable...working on 3.00 now, but this will be fixed soon, probably even included... ;)
calus
This bug is still not fixed in OctaneRender for Maya 3.05.1 - 9.16
The Height and Mid Level attributes sliders are unusable and crash Maya while in IPR.
Pascal ANDRE
calus
"height" slider fixed in OctaneRender® for Maya® 3.05.2 - 9.20,
"mid level" slider still has the problem.
Pascal ANDRE
calus
This issue is solved in OctaneRender for Maya 3.05.3 - 9.21
Pascal ANDRE
Return to “Bug Reports”
