pixel crawl question
Carrara (Integrated Plugin developed by Sighman)
protovu
Hi Sighman,
On the pixel crawl represented in the attached, is there some setting I have wrong in the render?
Thank you,
Rick
pixel crawl.mp4
(3.49 MiB) Downloaded 4729 times
EddyMI3D
How many maximum samples have you set?
My Rig:
PC with AMD FX 8350 @ 4,00 GHz
Win 7-64
Nvidia GTX 760
Nvidia GTX 970 (only for rendering)
About 6 TB of disk space (768 GB of SSD)
Octane/Octane for Carrara
Sighman
If you are using the Direct Lighting or Path Tracing kernel then try enabling 'Static Noise'.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
protovu
Thanks, Sighman.
I will try the static noise enablement. And thank you for fixing the Filename/Directory issue.
Hi Eddy,
I was at 300 samples.
Best regards,
Rick
EddyMI3D
Maybe also a bit few...
My Rig:
Win 7-64
Nvidia GTX 760
Return to “Carrara”
