Maya® Version Requirements
This release will work with Maya® Version 2016 64-bit on Linux operating systems.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
1. Quick fix, so using "File name prefix" in Render Settings or for command line rendering the "-im" flag does not produce a default file "OctaneRender_ALLpasses0001" anymore, but uses the intented naming.
Installation:
- Just run the installer to see its command line keys.
DOWNLOAD
OctaneRender for Maya - v7.24 Linux
OctaneRender for Maya - v7.24 Linux DEMO
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
