OctaneRender® for Maya® 2.24.2 - 7.24 Win [OBSOLETE]
k.a.schubert
Maya® Version Requirements
This release will work with Maya® Versions 2013.5, 2014, 2015 and 2016 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • 1. Quick fix, so using "File name prefix" in Render Settings or for command line rendering the "-im" flag does not produce a default file "OctaneRender_ALLpasses0001" anymore, but uses the intented naming.
DOWNLOAD
OctaneRender for Maya 2.24.2 - 7.24
OctaneRender for Maya 2.24.2 - 7.24 Demo
viewtopic.php?f=24&t=50498
Yours,
The OctaneRender™ Team.
itsallgoode9
It's about damn time that texture power defaults to 1 haha. I'm still confused why it always defaulted to 0.9 before. Glad to see that's finally fixed 8-)
calus
Thanks for the quick fix, I confirm it works nicely in my tests now :)
Pascal ANDRE
k.a.schubert
As far as I know 1.0 as a default value could have lead to weird results in earlier versions of Octane, since its the boundary value.
So the idea was to start from 0.9 and move towards 1.0 and see how the results change. Not clear how much it changed,
so feel free to report anything this way. ;)
calus wrote:Thanks for the quick fix, I confirm it works nicely in my tests now :)
Glad to hear :)
Jolbertoquini
the older version gave me problems at Deadline when was saving the images I will check with that one...
Octane Render for Maya.
https://vimeo.com/jocg/videos
http://www.hmxmedia.com/
Vyoor
I have a problem with cached particles - maya is crashing when internal MBlur is enabled. The same with realflow meshes. I don't know in which version problem appeared but in Octane 2.23.2 - 7.4 this things was ok.
i7, 4x GTX 780, Maya.
k.a.schubert
Vyoor wrote:I have a problem with cached particles - maya is crashing when internal MBlur is enabled. The same with realflow meshes. I don't know in which version problem appeared but in Octane 2.23.2 - 7.4 this things was ok.
Hi Vyoor,
which version this was okay? We did not reach 7.4 yet.
Best,
Kai
calus
Hi Vyoor,
Best,
Kai
yes, we did. (7.4 is to be read like 7.04)
viewtopic.php?f=28&t=46999
Pascal ANDRE
calus
I confirm internal motion blur works ok for cached Maya legacy particles instancer until 2.23.2 - 7.6 and fail in 2.23.2 - 7.7
Also it doesn't work with nparticles or with memory cache, in any version.
Pascal ANDRE
k.a.schubert
calus wrote:I confirm internal motion blur works ok for cached Maya legacy particles instancer until 2.23.2 - 7.6 and fail in 2.23.2 - 7.7
Okay, I noted this down, but at the moment am busy so don't expect a quick fix.
Sorry,
Kai
