render with animated image sequence dont work
Andygraph3D
The animated image sequence (like texture on prop) dont show on render, where i wrong ?
V. 2.24.1.61 (32bit)
windows 7 64 bit
poser 10
Andygraph3D
no solution ?
It is working OK for me on the latest test release (3.0.6.70). Did you check the manual on how animated textures work? https://docs.otoy.com/Poser/?page_id=160
Andygraph3D
i have check, but the problem persists.
The problem maybe is on my version, the last for 32 bit version :-(
i have only poser 10 32 bit ...
Andygraph3D
can you fix it ?
The last animated texturemaps issue that was fixed was in 2.22.2.42, and you are using a later version than that, so it should work.
Are you definitely ticking the Refresh Scene Each Frame checkbox? Does Poser say that it will be rendered as an animated texture?
There is not much I can do to support the old 32bit versions of the plugin - I'm all 64bit now.
Andygraph3D
For clarity, you should write to the download page, that the latest version to 32 bit has problems with animated image sequence ... :(
Andygraph3D
Where i can find the old plugin version for download ?
Is there i way for make a downgrade of plugin ?
I don't believe that it does have a problem. According to my notes, it is exactly the same codebase of the current plugin for this functionality. Are you absolutely certain you are following the instructions in the manual?
Which exact version do you want?
May I recommend you update from 32bit to 64bit, then you can use the latest release of the plugin.
Andygraph3D
Paul excuse me but I followed your instructions but without a positive result, please send me the old version of plugin 2.22.2.42 and i try it ...
Return to “Poser”
